Rep Power: 10 ![]() |
Stock ECU reads it.
OD switch is also read by the stocker ECU.... Stock ECU's suck I use mine for start in gear protection and for my remote start
#2 | ||
Half bubble off plumb
I can't remember if FD's have this as well, if so that would work great with a remote start, yes I do realize this is the 2nd gen section...
J.
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it." 360 gamertag: Tichlis |
#3 | |
I used it as the gnd for a relay that allows power to pass through it for ththe remote start
#4 | |||
Thats exactly what I would want it for... I want that new alarm the 'drone' I think it's called.... Everything is done via internet/SMS and you can track your cars local by GPS too.... But I did not want to put in one if I could not use a neutral safety switch easily.... Thank Goodness Mazda has a habit of over engineering some things :P J.
