Old 05-17-2011, 10:11 PM   #1
Next on the Chopping block was the radiator. When I first had Griffen build me this rad, they built it with 1.5" inlet, 1.75" outlet becuase someone didn't read carefully (not a big deal and to Griffins credit, they wanted me to ship it back to them on thier dime, send me a new one with the proper size on it. I ended up just hitting up my tub of ky (seriously) and smearing it on a stock hose and on the barb, adding a little heat and it slid on and never leaked, so I didn't see the need to send it back, but kudo's to Griffin for their service, couldn't be happier) ANYWHO.... I never liked the way I had it plumbed. It just bothered me. It didn't leak, but getting the t-bolts on was a pain and it just wasn't very visually appealing... so out came the hack saw.
OH NOES!!!!
After that it was pretty easy to weld on the -16 bungs. Griffin warned me about transferring the welding heat to the epoxy on the sides. The answer was to just fill the rad with water. What you DON'T want to do though is fill it with water and then seal it off. When you're welding, the heat from the welding heats the water. This causes it to expand. If you're unlucky enough you get a blowout and hot water in your face...... and no this never happened to me
When Griffin originally built this rad they added a 1/4" female NPT bung on the passenger side tank for the AST... however they put it in the wrong spot. Not a big deal, just add another one higher though, on the adjacent plane where the top of the rad will be. This is the second fitting that is connected to my AST. You can see it on the top right in the pic. You can also see the -6 Male bung lower left that I use for flushing and draining. It works very well and again, no hose clamps.... I CAN'T STAND IT when people plug unused coolant fittings with bolts and RTV... some may or may not remember this rant... you probably would as I had almost completely lost my voice and was getting rather worked up about it
And the rad mounted..... damn that looks alot better than what I started with
