That's typical.
It's actually aluminum oxide. It's galvanic corrosion due to having two dissimilar metals (steel side irons + aluminum rotor housings) and an electrolyte (coolant) - that's basically a battery. -Ted |
IT'S ALIVE!
Gah, of course! In my search to find something I've managed to forget even the most basic material science. So what exactly should I be looking for given the circumstances? I have a couple other pictures of the rear iron and rotor housing but nothing looks out of the ordinary (to me).
Check the inner water jacket o-ring.
Look for discoloration or distortion. Check the area of the side iron on both sides of the water jacket o-ring groove - look for discoloration. The inside (toward the combustion chamber) edge area should be a uniform black - if there is a "clean" area, that could be signs of water leaking into the engine. -Ted |
