Rep Power: 21 ![]() |
Redid the tire mounting so it sits in the spare tire well. Move the triangles, and am planning on changing the jack. Going to go up and find an FC rx7 jack since they are aluminum, weld a lug to it for easier lifting and a plate for surface area since the underbody HDPE rendered the pinch rail style thing useless.
also put a surefire flashlight and a leatherman in there. That should be it for "adding" shit. Now, im going to look if there is anything i can remove for weight savings. Probably not much though, which is fine.
