Rep Power: 10 ![]() |
Yes, it usually gets shimmed, but the last time I had the pan down I removed the shims hoping to lower my oil pressure and it didn't do a damn thing.
What are your pressures like? GENERALLY when an o-ring blows out the pressure is abysmal. Not sure why mine continues to seal
#2 | ||
I have radioactive semen
from what i remember, idle pressure was normal. it would shoot up to about 80 psi (stock gauge) with throttle and just kind of sit there through the gears, but once i was cruising on the highway, it would slowly start falling. it never got critically low though. keep in mind, for most of the 2 or so months that it ran, i was limiting myself to 4000 RPM because of break-in on the new bearings. |
