Old 04-18-2011, 01:09 PM   #1
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Finished project.
Kind of tight on the passenger side of the engine bay, but this is how things look.
I drilled a hole next to the radiator. Blitz BOV I traded some parts for. Used some clear tubing I had around instead of normal vac tubing which I didn't have.
The sun was killing this shot, but shows the IC piping.
The Subaru Impreza intake pipe installed.
I used an S4 turbo MAF sensor, changed the connector wiring, and have a piece of filter clamped on.
View from above the turbo. One of the heat shields, Oil and coolant lines installed. Also one of my attempts to fix an exhaust leak. I still have a leak.
Oil feed line and source.
Oil return.
Oil temp source via T fitting.
Old 04-18-2011, 01:53 PM   #2
N.RotaryTech
Home-brew Rotary
Now for the details.
The turbo is a Turbonetics T3/T4 series, I forgot the specs, I wrote them down someplace, have to find that.
It has an external wastegate that apparently came with a 10 pound spring in it.
720cc (not 750cc as I posted before) injectors in the secondarys, with 6 ohm resistors installed inline with the wiring to them, actually located next to the ECU under the carpet.
Stock Turbo AFM.
Stock TII intercooler.
Blitz BOV.
The engine is the same as I posted before. S4, 9.4 comp rotors, mild porting on the housings and end-plates.
And for the best part...
All this runs on the stock S5 NA ECU!
It will boost up to 10psi, but runs really lean up in that range.
Around 5psi AFR's are perfect though. 11's and 12's
Ive taken it for a drive / boosting just a handful of times.
But found out last night after a drive that my Nopi stage 2 carbon kevlar clutch filled the engine bay with burnt/slipped clutch smell.
So I might have to replace it after DGRR'11
I also found that the turbo's oil seals are bad, leaking through the exhaust and leaking externally.
So with all this, I'm expecting a possible clutch, turbo & engine rebuild after DGRR'11.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
