| 3rd Gen RX-7 Engine Parts Only Engine Related parts ONLY! |
Blitz boost controller and a bunch of engine parts
Pics can be found here http://s240.photobucket.com/albums/f...rts/?start=all
ENGINE: Blitz DSBC Spec R (new never used) $290 Billet oil filter pedestals w/npt ports and hardware $65 each JDM Vac block $60 3" V-band clamps $50 each Primary Fuel rail w/injectors $60 Secondary Fuel rail w/injectors $70 (or both rails w/injectors for $110) MOP $50 MOP oem lines $10 (or free with MOP) Motor mounts w/good bushings (aluminum/steel) $100 Iron Set (front, intermediate, rear) $290 for the set or 110 ea E-Shafts $60 Rear stationary gear $35 Oil pump w/chain $35 ea Tension bolts $15 ea set Tubular dowel rods $10 ea set Water pump w/housing $70 Front counter weight $20 ea Metering oil pump gear $10 ea Oil pan pick up $10 ea Oil pan $30 ea Main pulley (oem) $10 Flywheel (oem, needs resurfaced) $20 ea DRIVETRAIN: Super*Now transmission cooling plate $220 BOOKS/MAGS: $15 each RX7 magazines vol 7, 9 Let me know if you have any questions, I accept paypal. You can pm or email me at seeltuned@aol.com The only thing off the top of my head I am looking for is a set of interior trim pieces. Condition does not matter just as long as they are not broken. |
Blitz boost controller sold!
Can you do 65 shipped for the Oil pedestal? I'm in NY and believe you are also...
one broke moderator
I have a couple of them left, my paypal is the same as my email seeltuned@aol.com I am firm on pricing for the pedestals shipped would be $70.
Here is an update:
ENGINE: Billet oil filter pedestals w/npt ports and hardware $65 JDM Vac block $60 Primary Fuel rail w/injectors $60 Secondary Fuel rail w/injectors $70 (or both rails w/injectors for $110) MOP $50 MOP oem lines $10 (or free with MOP) Rear stationary gear $35 Oil pump w/chain $35 ea Tension bolts $15 ea set Tubular dowel rods $10 ea set Front counter weight $20 ea Metering oil pump gear $10 ea Oil pan pick up $10 ea Main pulley (oem) $10 DRIVETRAIN: Super*Now transmission cooling plate $220 |
