Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Garfinkle's Motor Works
Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's
Old 03-27-2011, 10:19 PM   #1
Garfinkles Motor Works
I will need to have a stock gasket to see if it is the same as FD.If it is not the same then I would need to write a new set of programes to cut the plate on the EDM .
Old 03-28-2011, 08:31 AM   #2
Pete_89T2
Pete_89T2's Avatar
I have a spare gasket for the turbo side that I can trace on paper and either scan into a .PDF to email you, or snail mail you the actual trace if you feel the scanned version won't be precise enough to work with. Unfortunately I don't have a spare gasket for the front cover side to work with. Hopefully someone on the forum could help out with that one, since I'm not going to have time to pull the pipe off the car to trace that side till next weekend.
