|  02-19-2011, 11:59 PM | #46 | |
| destroy, rebuild, repeat Join Date: Feb 2008 Location: Charleston, SC
				Rep Power: 18  | Quote:
 things to do before DGRR2011.. found out my bb hybrid somehow blew out the front oil seal, ordered a new seal and backplate, and sent it off to gpopshop to fix a pre-turbine exhaust leak problem. also the power steering is leaking from somewhere. and need to get sunroof welded shut
				__________________ 1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast | |
|  03-20-2011, 09:01 AM | #47 |
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  |
			Title changed!  How's are the lists progressing?
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- |
|  03-20-2011, 09:21 AM | #48 |
| I've been Wankeled! Join Date: Apr 2010 Location: Mildmay, Ontario, Canada
				Rep Power: 16  |
			Not worth a damn! Winter is dragging on and I can't get out to work on the car. I've got the rims basically done, the engine and 4 speed trans are ready to come out of the car, and I've got the front struts ready to be built. Still a pile of work to do.......
				__________________ 1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place 1974 Rx-4 all original 27,000 miles 1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place |
|  03-20-2011, 12:32 PM | #49 |
| BOILED PEANUTS!!! Join Date: Jun 2010 Location: Jacksonville, Fl
				Rep Power: 16  |
			Get some new tires for the rear, and bank enough cash for the gas to get there.
				__________________  www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." |
|  03-20-2011, 04:20 PM | #50 |
| RCC Loves Me Not You Join Date: Mar 2008 Location: Colorado Springs, CO
				Rep Power: 20  |
			1. possibly paint engine bay (but probably not) - Done 2. possibly install ducting for the VMIC - maybe when I get the engine back in, but I'll probably wait 3. hopefully new coil setup and reinstall cruise control - decided to stick with stock coils and put them back in stock location, and did reinstall cruise control right before the engine blew 4. possibly construct custom gauge pod setup/change gauges - too much of a PITA but I did change to SPA Techniques gauges and different pod setup, and moved EBC to DIN under stereo. Also installed cable connectors into DIN so you just plug in like the back of a computer in order to tune 5. get the front fenders modified to match the rear fenders - they are modified but they look like crap, I guess I'll have to do it myself 6. ss braided lines and reroute for water injection - Still trying to figure out what lines to buy. Might also buy some new oil cooler lines to run instead of the current SS braided lines. 7. possibly move battery again this time to storage bin behind passenger seat - haven't relocated battery again yet, but I am rerouting my power line to go straight to the starter instead of through the engine bay to the front. 8. help roommates get their FDs running/finished so they can go too - can't help them if they won't work on them themselves haha, but this is still going to happen 9. I also forgot I want to get some strut bar spacers made so I can get rid of the washers. - Done 10. rebuild engine - should be getting engine back this Tuesday, will dress it with accessories Wednesday and install by the weekend with any luck 11. replace BRAND NEW oil cooler that got ripped off while trying to pull start - Done 13. figure out why power steering is seeping - replaced all o-rings and the hose, so hopefully this works I also got all IC piping, the IC, UIM, compressor housing, water pump housing and filler neck, A/C / P/S bracket and oil filler neck all powdercoated. Got the LIM, turbine housing, manifold and DP ceramic coated again, some other parts anodized and most of the various brackets and brake booster metal line all done in black oxide. I still have to figure out some way to paint or coat the throttle body and water pump so they will be black too, and may paint the power steering pump too, not sure yet. I also want to install a new P/S oil cooler line but I may wait to do that. Oh, I also finally hard mounted my relay box onto the front crossmember. I'm probably forgetting some things even. I've been a busy boy. But if I can get leave I'll definitely be at DGRR. |
|  03-20-2011, 10:12 PM | #51 | |
				Rep Power: 16  | Quote:
				__________________  www.rotarycarclub.com "The way a Rotary engine makes power is ferocious, much like having a chainsaw under your right foot." | |
|  03-20-2011, 10:15 PM | #52 |
				Rep Power: 20  |
			Thanks!  I love working on it almost as much as I love driving it lol, and usually once I start working on it I get on a roll and finish a lot.
|  03-21-2011, 12:11 AM | #53 |
| RCC Contributor Join Date: Mar 2008
				Rep Power: 18  |
			My list is for the most part is done now it's just 2nd checks and yearly matinence
				__________________  85 rx7 gsl-se - AA tags/ never ending project will never run |
|  03-21-2011, 06:40 AM | #54 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			Well, I bought a couple first gens since this thread was started. So far I have- Ordered a shitload of parts Swapped in a LSD disc rear end Looted another FB for most of the interior BBS wheels Holley Carb kit MSD 6AL Holley Blue fuel pump/regulator Waiting on installing the front springs, rears are done. And trying to locate an exhaust system, or at least a 12a header.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  03-21-2011, 04:55 PM | #55 |
				Rep Power: 20  |
			^So are you bringing one of the first gens or something else?
|  03-21-2011, 07:45 PM | #56 | |
				Rep Power: 22  | Quote:
 Had to order a stud kit to use the BBS wheels. That sucks, but at least I won't have stupid wheel bolts anymore. Lol. The MSD showed up today, fuel pump shipped today, new brake booster shipped today. So things are coming along. All the parts should be here by the weekend, so I can get to wrenching (again). At least this time it won't be as labor intensive as single handedly swapping rear axle assemblies, by myself, in the driveway. Charles is rebuilding the Holley carb, and getting it set up to drop it (very thankful). I need to get the car over there to put in an FC oil cooler and take off the window trim to be powdercoated. Then, back to the house to start smoothing the body for paint! Someone needs to hook me up with a glass sunroof!! And a header, and a muffler. Poop.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 | |
|  03-28-2011, 12:18 PM | #57 | |
| Rotary Fan in Training Join Date: Feb 2008 Location: St. Pete
				__________________ Scott Neville 1984 ITA (converting to something meaner) 1984 13B (Wolf 3.x) 1986 EP (Wolf 4.56) 1991 (Stockish engine, Wolf 3.0) 2005 RX8 Auto (Wife mobile) Life=counting the time till the next race... | |
|  04-04-2011, 12:54 AM | #58 | |
| Member of the D club Join Date: Apr 2009 Location: Quinlan, TX
				Rep Power: 17  | Quote:
 Clean up-Check Tire-Next pay check Radiator-Soon So the major one is done, gotta get my break-in miles before leaving. Can't wait.
				__________________ Follow my Spark Yellow restoration: http://www.rotarycarclub.com/rotary_...ad.php?t=12726 | |
|  04-04-2011, 01:20 AM | #59 |
				Rep Power: 20  |
			Got the engine in and it started today, WOOHOO!  However, it seems that now my alternator isn't putting out any power so my battery isn't charging.  I'd really like to get the break-in miles done in time to get it tuned before coming out so I can REALLY have fun but I'm not sure I'll have enough money to get tuned AND come to DGRR.
|  04-04-2011, 01:48 AM | #60 |
				Rep Power: 10  |
			Skip the tune and just dial in the cruise stuff.... there will be enough people there that know their way around a PFC that we should be able to get you up to WG dialed in to have some damn fun. Lets see.... left on my list 6 spd driveshaft brakes interior new trigger wheel new triggers front and rear MC and prop valve spare exhaust sleeves BNR stage 3's rewrap the exhaust evac tank damn... I've got ALOT to do.... oh, and of course dyno.... going to crush and embarrass the last record
