I did it back in 2003.
You can use the stock FD mounting points and make an adapter to mount it to the stock FC mounts. ![]() If you are hellbent on using the stick serpentine belt with the FD cover then you have to revise the coolant lines to match an FC radiator. ![]() I went single, too juch headache trying to make the twins work, I first went with a T04E then a GT35R, the later dropped my spool down and increased my WHP by about 80. ![]() Run a Haltech, Megasquirt, Motec etc... and save yourself the trouble. |
| Tags |
| 13b rew, fc rx7, wiring |
