#1 | |
rotaryevolution.net
Rep Power: 15 ![]() |
when the wires are worn the resistance gets thrown off giving a less accurate signal at the lower fuel level range where the most wear generally is. eventually the wires break and the gauge reads zero before the tank is actually empty, i figured you could gather what i was getting at. i have seen a number of 2nd gens with frayed wires below 1/4 tank which worked fine up until that point then dropped to 0 on the gauge as soon as they hit the bad spot. Last edited by Rotary Evolution; 03-06-2011 at 02:39 PM. |
