| Introduce yourself!! Tell me something about you and your history with rotary.. |
#11 |
so you got pistons oh wow
The one under repairs. It should be running by tomorow. I just dropped the engine on it all i need to do isto conect al the plugs and hoses, the intercooloer and the intake. ill let you know when I'm finished. I have a question. Who had previously rebuilt that engine? That engine had new apex seals and some other new crap on it. the reason it went was because instead of using a gasket set they used silicone and water got into the oil and it had a bearing failure. the rotor slamed against the iron and smashed the side seals into the grooves on the rear rotor. but everything else was intact. who ever rebuilt that engine had no clue on what he was doing. talk to you later. how is the white car working for you?
Polito Racing 2000 F-350 SD (Daily Driver) 2002 CBR 954RR (Back on the Road) 1987 RX-7 Turbo II(red bullet!!)
