#1 | |
Don Mega
You can buy the sensor on its own, but you need to buy the AF700 unit as you cant use the sensor on its own cause it has its own EPROM chip you need to fit into the controller which is the calibration for the sensor (each and every one is tailor made). Autronic sell a "lab grade" NTK sensor (though not chipped like the Neko) it's just a higher grade than the std L1H1 and is about $700 Au, this is the same as Motec will supply for a PLM if you get the shits with the inaccuracy and random failures of the Bosch LSU types they come with std. Hope this clears it up?
#2 | |
Rep Power: 17 ![]() |
I have used the PLX with no problems. The OLED display and daisy chain option for other gauges such as Oil Pressure, Temp, and Coolant Temp etc. Very neat options anyway.
Move from FC subsection to Rotary Tech subsection...
-Ted |
idahorotary.com
I have used a PLX in the same location for the last 20K miles with no problem what so ever.
87 TII-E85-600+ RWHP and climbing Life starts at 2 bar! Come visit my forum! idahorotary.com http://idahorotary.com/smf/index.php |
#5 | |
Rep Power: 20 ![]() |
