			 Don Mega
				Rep Power: 18 ![]()  |
			Will get on it tonight hopefully, if not by weekend.
			I currently run Dynatek CDI's, Dynatek CDI 0.5 ohm coils, RR designed Coil on plug system. I'll dig out the Current and electrical info on a typical idle setting. Its pulls as much current as some top magneto stuff   second restrike is right up there in "power too".When I compare this CDI system to inductive in off boost settings the engine is just much more crisp and alive, it will fire leaner air fuel ratio's (and richer too) it wont foul very cold plugs and the EGT is lower, and power is higher. Cost of my bespoke system is prohibitive for most people off the street. The MSD Dis2HO (high output version) with MSD small coils, and leads is a very high powered system, not as powerful as the Dynatek's 200+mj constant rating but its up there. Some of the old systems I used based on the Crane Hi-6 were quite good and idled very well (see my web site of a street port and bridge running these systems under the water injection page). 2 x Hi-6's on both leading plugs and LX-92 CDI coils.
	www.riceracing.com.au Worlds best Apex Seals Coil on Plug Water Injection ECU Calibration  |
