Old 02-23-2011, 11:17 AM   #1
from this point i ditched the sway bar BUT! its easy as dirt to make it work. Just mark and drill for the sway bar mounts. drop two bolts for studs and viola! sway bar. I just want to see if i can maximize range of motion of the front suspension. i can always compensate with springs rates.
From here i stitch welded just about everything. This is somewhat time consuming prep wise as all the seam sealer had to be removed. Then i marked 1" spacings along the seams as to get a 1" weld, 1" space pattern for the stitching.
For the dampers, i aquired some FC struts. After disassemlbing the FC struts and the FB struts it seems the FB springs fits the FC spring perch. The FB tops will the attach to the piston. The threads are the same between the two. The only differnce is the half moon cut on the FC but i cant forsee any issues with it. Testing will tell.
