| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
MG rocket
How do you determine the fuel pressure setting?
Hi all,
With a 13B Extend Port N/A 48IDA carb, I am guessing I need to have pressure set at 3.5 PSI. What are the symptoms if this is: A. Too low B. Too high? Thanks |
#2 | |
Waffles - hmmm good
- bad idle (rough or high) - floods easily - stinks - flames out the exhaust on decel Too low - runs lean or hot - plugs might be white after a high rpm run with shutoff - will idle fine and run fine up to certain rpms/loads and will then stumble
#3 | |
Custom User Title
Also, if the level is too high, it can cause dripping from the venturis. It may also affect the progression. If it's too low, it may have an increased tendency to stumble around corners.
MG rocket
Thanks guys,
My issue is it "hesitates" for a split second when I put the boot down - usually 2nd or 3rd gear. It is fumey / smelly on start up and idles rough when cold. So, as I have no fuel pressure regulator (soon to be fitted), I will see if this changes anything. Do you think 4 PSI is too high as a starting point? (I ask as my intended reg is the Mallory 4207 with a range is 4 - 12 PSI.) |
Waffles - hmmm good
Sounds like it may be running with too much pressure. It messes up the progression circuit when its high.
4 psi. might be on the edge but I don't run a weber, so maybe someone with clue can port up.
#6 | |
Custom User Title
I run 4.25 PSI base pressure with my DCOE, but IDAs may want something different.
Racing Beat recommends 4.5psi on an IDA, so going a little high probably won't hurt anything.
Going from memory I'm running somewhere between 4 and 4.5 on my 51IDA on a full bridge. Can't remember the jetting for the life of me however. Sounds like 4 is a pretty safe starting point.
2004 RX8 GT 1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb 2003 MazdaSpeed Protege 1988 RX7 Convertible - new project 2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog |
Reliable Source
Rep Power: 17 ![]() |
I run 4.5 on my DCOE base but it drops to 3.5 under accel. It still stumbles a bit off the line if you just crack the throttle, I found revving it enough to pump the accelerator pump works great.
#9 |
MG rocket
Thanks guys.
Great info provided. |
#10 |
I have radioactive semen
one thing to keep in mind is the accuracy of the gauge you use. i learned a long time ago (i think it was on Paul Yaw's site) that many popular gauges are notoriously inaccurate. years ago, when i was tuning my Dell'Orto, i paid much closer attention to the engine and what it was telling me, as opposed to the gauge. if i recall, the engine pretty much liked to be about 1 PSI (indicated) lower than what was recommended by RB.
#11 |
buy this one....http://mrcmfg.com/catalog/product_in..._id=163...your best bet for accuracy
#12 |
Waffles - hmmm good
+1 on the guage.
Factoid: Most guages are only accurate in the center 30% of their range. I have a 0-15 psi guage from Summit, liquid filled, nice guage but its notoriously inaccurate for measuring 2.5 psi. I set it using the engine running and let it out until I hear the rpms pickup and then back it down a bit. It indicates around 2 to 3 at this point but I can't depend on it being the same from one time to the next. The 0-5 psi guage from ReSpeed is the best, I may get one when I go down that way for the Mitty.
#13 |
MG rocket
The plot thickens...
I have just installed the Mallory 4207 Fuel pressure regulator with matching Mallory gauge. This regulator has a range of 4 - 12 PSI. It was installed exactly as per instructions - super easy! How come I can set it for 2 PSI? I have set the Reg at 4 PSI which is half way in the Reg adjustment. (I expected it would be at the minimum setting!) Whilst it serves the purpose set at 4 PSI, I am now wondering if the fuel pump (which I was told is 7 PSI) is actually running alot less PSI???? Car ran well before hand and the reg was filled as a precaution. Am I missing anything? Is the reg working? |
#14 | |
with the results in reverse order, i found that the 72gph/6psi pump only delivers a little more than 4psi @ the carb, its also WAY short on volume. so i got rid of the regulator completely, because mazdas comp spec for the weber is 4.3psi, and that's about what i'm getting. so how much PSI can you run? i think the factory spec is 3.5, which should be fine. the float level is important. with the engine running you should be able to look down the venturi's and NOT see fuel dripping from the boosters at idle. if you are, the float is too high. i set my float for 4+ psi, so dropping the fuel pressure might lean it out, i didn't do the testing in an order where i really know that. oh yeah and i bought a 5" diameter 0-5psi gauge (the one mr yaw used to recommend, i think) |
#15 | |
Custom User Title
My Mallory 4309 is rated for 3-12 PSI base pressure, but I can get it down to ~1 PSI. And that's with a pump designed for 40 PSI.
