Old 02-18-2011, 12:50 AM   #1
GtoRx7
GtoRx7 is on a distinguished road
This shows the internal teflon sheets
Milling the actuator grooves
Placement of the 4 ball bearing support system, and rounded the inside slider
Test assembly together with actuators
Showing movement of slide throttle
Hand bending curved end caps
Test assembly with radiuses on ends
Hand fitting and clearancing of the end caps
Smoothed and matched curved surfaces
Finished and polished slide
Countersunk plate bottoms, for spring perch. Much stronger than tapped aluminum
Exploded view of all the parts finished to the slide throttle setup
Finished assembly with button head stainless hardware
Air horns placed, just to give a idea of what it will look like fully finished
DEFINED AUTOWORKS
Where concept meets results
Black 1994 FD 4-rotor 610rwhp all motor
Red 1970 Mazda R-100 with 10a
Black 1974 Mazda Rx4
Black 1984 Gsl-SE 13b-re streetport 230rwhp
GtoRx7 is offline   Reply With Quote
