Old 02-15-2011, 01:48 PM   #31
RX-7 Chris
RX-7 Chris's Avatar
My parts list is growing.
I still need to do the tranny mount and drive shaft. I'm going to hold off on the motor mounts.
I have a Racing Beat muffler to put on the car. It used to be mine and it has come back around to me. I also ordered most of the parts I need to finish the motor.
I still need to have the injectors cleaned. Rebuild the OMP (I already have the kit from pineapple racing). I need to order the Atkins Six Port Actuator Valve Kit, K&N air filter, and one coolant line to be able to finish all the critical things on the motor. In the coming months, I'd like to get NGK Power Cable ignition wires and Bönez Street Exhaust mid pipe to finish the motor.
http://coloradomazdaclub.com
1984 RX-7 GSL-SE
1983 RX-7 GSL PARTING OUT + EXTRA
1964 Ford Galaxie 500XL 390 auto
1970 Ford F250 4x2 390 4bl C6
Old 02-15-2011, 02:45 PM   #32
RX-7 Chris
RX-7 Chris's Avatar
Thanks to TitaniumTT for moving the thread to the build section.
1984 RX-7 GSL-SE
Old 02-21-2011, 04:10 PM   #33
RX-7 Chris
RX-7 Chris's Avatar
I did some more cleaning under the hood:
1984 RX-7 GSL-SE
Old 03-07-2011, 04:30 PM   #34
RX-7 Chris
RX-7 Chris's Avatar
I have a bunch or parts ordered. I have everything I need to basically finish the motor ordered or will be ordered this week.
K&N filter, spark plug wires, battery hold down, coolant line, air control valve gasket, air control check valve, muffler gasket, thermostat gasket, A/C belt and fuel filter. I still need to send the injectors to witchhunter and order the Atkins Six Port Actuator Valve Kit.
I also picked up a ash tray over the weekend with a perfect finish on it. I have a brown sunroof crank on it's way as well.
1984 RX-7 GSL-SE
Old 07-11-2011, 09:33 AM   #35
RX-7 Chris
RX-7 Chris's Avatar
I've made a ton of progress on the car. I have everything posted on my blog: http://chrischillino.com/
1984 RX-7 GSL-SE
