				Rep Power: 16 ![]()  |
				Bench bleeding a new/rebuilt brake master cylinder
			Would it be acceptable to install the MC on the power brake booster, and "bench" bleed it using the brake pedal? Would still be using the plugs/tubes that came with the MC per instructions, seems the only difference is I'd be using the car's brake pedal linkage to operate the MC instead of clamping the MC to a bench and manually pushing the cylinder. Just think it would be less messy to install the MC dry vs. wet, hence the question.
				Rep Power: 22 ![]()  |
			That is the way I did mine on my old 626 turbo, since I didn't have a vise.  It worked fine for me.
			Now I have a pressure bleeder, much easier!
	1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5  |
			That's good to hear. I have a pressure bleeder too, just wasn't sure if that method would work properly when starting with a dry MC. I figured the air trapped inside a dry MC during assembly might be too hard to fully remove with the pressure bleeder alone without first doing a bench bleed, since the MC piston stays put when you use the pressure bleeder. Think I'll try bench bleeding the MC in car first, then hit it with the pressure bleeder to bleed the entire system.
			 Rotary Masochist
				Rep Power: 18 ![]()  |
			Use the pressure bleeder.  No need to do the bench bleeding when you have that.  Much easier.
	_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI  |
				Rep Power: 10 ![]()  |
			mmmm pressure bleeder... Maybe I shoudl put that on my Sears want list.
			You can "bench bleed" while on the booster, just pull the check valve off the booster.
	-The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED-  |
			only one i know of is the Motive.  are there any other/better designs?  motive is pretty damn cheap and seems to be amazing
			The Motive unit is what I got. It has the pressure gauge on the tank, and came with an assortment of caps, cost was less than $50. For what it does, it is a great product. Unfortunately the Motive kit I got didn't come with a cap that is an exact fit for the MC's on my FC, and the "universal" cap they included in my kit is just too clumsy to use -- no room to route the chains under the MC and secure it, so I could never get it to seal properly. Solved that problem by fabricating my own cap with a junkyard MC cap from a 90's vintage Mazda, a brass nipple and some sealant. My homemade cap works on my FC, and also fits my '03 Mazda Protege5.
		#8 | |
 Did yours come with a BMW cap? Lol, if so send it my way, and I'll send it back when I'm done (or bring it to DGRR). Seriously.
		#9 | |
 Do you have a picture you could post of how you fabricated it? I'm pretty sure I know what you did, but I like pictures to verify things.
	2004 RX8 GT 1986 RX7 Track Car: 13B Bridge Port w/ Renesis Internals and Weber Carb 2003 MazdaSpeed Protege 1988 RX7 Convertible - new project 2004 Impreza and 2003 Legacy wagons for hauling groceries and The Dog  |
		#10 |
			It literally is just a Mazda cap with a hole drilled in the middle, a barb fitting put in the hole, and then JB weld or something else that seals REALLY well (has to hold up to psi).
			I wonder if the Miata cap they sell fits?
		#11 |
			Honestly, that is what I had pictured.  I guess I just didn't believe it was that simple.
		#12 |
			Yup, it's that simple -- djmtsu gave an exact description of my homemade cap. I can post some pics tonight if I have time. The only caveat is to make sure the donor junk yard cap still has a good rubber seal/washer under it -- you'll need that for a good seal with your MC when you screw it down.
	The cap I picked up in the yard was from a '90s vintage 626, and it fits my FC ('89T2) and my '03 Mazda Protege5, so it might fit the Miata as well.  |
		#13 |
			Something about pressurizing a fluid that can strip paint kinda bothers me.  What about the air-comp powered vac ones that pull fluid from the calipers?
		#14 | |
 Another way is with a simple oil hand pump (think like what the Tin Man uses to stay lubed). Fill it with brake fluid, attach a hose to the end, and then onto the bleeder. Pump it so there is fluid to the end of the hose, crack the bleeder and pump it up through the lines to air escapes at the MC. I've done it that way too. Works great too.
		#15 | |
 Pressure bleeding works very well with only 2~5 PSI pressure; just enough to push the air bubbles & fluid out the bleeder screws without risk of blowing any seals. So if you buy or build one for yourself, just make sure it has a gauge.  |
