Old 02-03-2011, 04:26 PM   #1
Sharingan 19
Sharingan 19 is on a distinguished road
If you've got a standalone and can tune it, or don't mind running a little rich under cruise, ditch the voltage reg and wire it strait. One less thing to fail.
I have an rtek 2.1, which is based on the stock map (which accounts for bi-voltage operation). It does have fuel adjustment which I could use to lean it out but....why? I'll let Mazda figure out the fuel economy (this is a daily) and I'll spend my time refining the boost portion. As far as failure, I've found one case of either the resistor or relay failing....I like my odds But when the time comes for me to sell a kidney and get a Motec, I'll rip out everything stock I don't need and rely on the ecu.
You're thinking about it backwards. The more voltage you give the pump, the less A's it needs at the same pressure. So, you won't burn the thing up running it constantly. My pumpS see running voltage minus about .2V and I've run them for 21 hours pretty much strait. If he burned out a pump while running dual intanks, my first guess would be insuffiecent wiring, both in size and voltage. The smaller wiring will create resistance, the two pumps pulling more A's than it should causing heat. Heat causes more resistance, and it just becomes a downward spiral untli the V goes too low, the A's go to high, and then they burn up
Ahhhhh! I've never liked electronics, at least the planning/understanding part. Guess I'll have to bust out those old physics books....I make some damn sturdy connections though,lol. I don't remember the details of his setup, simply that a pump was burned up.
Sharingan 19 is offline   Reply With Quote
Old 02-03-2011, 05:36 PM   #2
The FPR will take care of most of the difference as far as tuning goes.
Mazda doesn't always do the best job of economy. I have a friend of mine, we went out and street tuned his Rtek one night and he got something like 28mpg on the way up to canada. Now, granted this was an n/a but I never got close to that when I had a ecu.
Bottomline is, using the stock Rtek map is a weak excuse for wanting to keep a voltage reg. Lower voltage means higher amps, I'm not sure why Mazda did it that way, but I don't think it's needed, therefore it goes away.
First time I've heard of a pump burning out for no reason, there must be a reason...... could be low voltage caused by a bad voltage reg
Old 02-03-2011, 08:30 PM   #3
Sharingan 19
Talking
Well, before all these fuel related problems and subsequent upgrades I got 17/25 like clockwork. I'm just trying to get back there, I'll tune the rtek when I get a chance and hopefully I can shoot for that 28mpg mark. At least now I don't have to get 13mpg while I wait.
"You" don't think its needed. "You" would also work 48 straight hours for the privilege of driving another 14.... "You" would also spend the time/$ to fine-tune the drivability portion of your map to near perfection. "I" don't possess the resources in $, skills, or patience to commit to doing that at this time. what "I" know is that of all the FC people (not running a stand alone.....and most who are) who have re-wired their fuel pump for constant 12v do not get acceptable fuel mileage for a daily driver. Lol.
:lmao: could be, I don't know anything about the FD voltage regulator....apples to oranges.
Old 02-03-2011, 09:29 PM   #4
46 hours straight.... gonna try to break the 2 day mark this time around.
A voltage regulator is only slightly related to fuel mileage, the FPR compensates for most of it.
Think of it this way.... constant 13v+ is going to draw less amps and create less load/heat on the pump. That alone is reason enough for me. Tuning for fuel economy is pretty damn easy, just takes two people and a few hours cruising around.... or datalogging.
