Old 02-03-2011, 01:03 PM   #1
Sharingan 19
Sharingan 19 is on a distinguished road
There are some additional considerations when modding the s5 cluster. At the top of my list personally is that every s5 cluster I've seen had been pink and not orange, making it pretty difficult to match.
Also, the gauges in the s5 are apparently 45mm, but the gauges are a little bit larger so the holes would need to be enlarged if u wanted to mount them in the stock cluster. This presents a potential clearance issue w/the glass cover as even w/ the custom panel I made (which mounts behind the stock material) there are only a few mm of clearance between the gauge face and the clear cover.
Sharingan 19 is offline   Reply With Quote
