| Carburetors and Carb Tuning.. All info about old school carb set ups.. |
#1 | |
Custom User Title
So you're not using any velocity stacks at all right now? I can tell you that getting some will add quite a bit of airflow.
I've always heard that ram air doesn't really help much, and will increase drag somewhat. You say you have no room for a cold air intake, but there are all sorts of ways to route ducting to the carb. Pic of your engine bay?
Waffles - hmmm good
I assume your rotary is in a midget. Not much room I'm guessing.
You should have velocity stacks, even shorties will make a difference. They are required to make the air flow good coming into the venturies. If you run an airbox or a cold air intake, make sure there's at least 1.5 inches clearance above the stack openings or it will impede the flow. Also make sure your running a filter or your carb will get messed up. And yes, we want pics
