Rep Power: 20 ![]() |
Why bother using them in the first place?
Im not an expert on bearing technology, but im not sure a bearing of that kind can handle the load against it as well. If it was a good idea im sure the small block chevy would of had a crank bearing like this a long time ago. Only reason i meantion a s.b.c crank is because we all know that engine gets all the minds in the world wanting to better it.
#4 | |
If it goes, what's to stop it from having the needle bearings clogging the oil passages? Where as compared to a regular journal bearing, if it fails, what's going to clog the oil passages?
Rep Power: 10 ![]() |
Where is that from? Website, links, more infor..... is that from a 16X? Seems pretty wide to me.
Less friction = more efficient engine
More efficient engine = more power using less fuel Or course, the downside is that needle bearings are less reliable versus journal bearings. I'd imagine service interval is a lot shorter for these needle bearings versus journal bearings. If you're building a "race engine", this is not going to matter. -Ted Last edited by RETed; 01-11-2011 at 11:02 AM. |
The big advantage to roller bearings is that they do not suffer accelerated wear for short periods of non-lubrication (if they get hot, it is a different story). This is good for starting (no oil pressure). The biggest problem with them is as stated above, there are more wear parts than just the oil film. Thus changing the oil does not completely replace the wear items in the bearing. The journal bearing is truly awesome for longevity under high loads and high speeds.
The picture that is shown is from a small air-cooled rotary that has no pressurized lubrication system (mixed oil in the gas). This is why the roller (or needle) bearing is required.
1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 01-11-2011 at 07:49 AM. |
#8 | |
Rotary Masochist
They are. Needle bearings for cams and crank shafts are common place in high end circle track engines.
_______________________________________________ One stop Haltech, AEM, Syvecs shopping. Installation and tuning. http://www.lms-efi.com Free support. Drop us an email. chris@lms-efi.com 502-515-7482 Facebook @LMS-EFI |
#9 |
I only googled roller ratary in images and came across it. It was a link to ausrotary.com.
#10 | |
#11 | |
Thanks. |
#12 |
Rotary Masochist
Needle cam bearing in a V8.
#13 |
That look very much like a rotor from Woelfe Engineering's Aixro rotary kart engine.
http://www.woelfle-engineering.com/ It's a 294cc single rotor engine that gets about 40hp. The housing is water cooled and the rotor and bearing are cooled by the air/fuel/oil mixture, like NoDOHC said. Here's an illustration from K. Yamamoto's Rotary Engine book:
#14 |
40 hp???? I think thaty would work well on my riding mower
#15 | |
Less parts = better reliability This is why journal bearings are used in the most inaccessible locations. Anyone who has lost a pilot bearing on their RX-7's knows what I mean... -Ted |
