| Drifting All things sideways |
#1 | |
Rep Power: 20 ![]() |
More to the point let's look at the actuality of the situation: Sidewall flex or more accurately stated; deflection under cornering load varies from tire to tire, this temporary load instigates the deformation and increased stress on the tire. This load also is temporary and allows the stress to be dissipated once the load is removed. If you're cornering with a stretched tire sidewall flex is removed which means you begin to affect the plastic deformation criteria of the rubber. Sidewall deflection under normal loading conditions of a proper tire are designed to remain in the elastic deformation region. That is the same region you are taking up when you stretch the tire. The more you stretch the less elastic region you have available to allow it to absorb stress. This is fact. Look at any stress strain curve if you don't believe me. Furthermore you have yet to address the issue of proper tire inflation. Something as simple as inflating a tire should be easy to validate with data. Surely you can provide at least that much for us 'nay sayers'?
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 12-23-2010 at 03:57 PM. |
@Vex, that's the point. There are no hard facts about it, there haven't been any studies to my knowledge that prove this one way or the other. I can only go by my experiences and stretching tires works for me.
When you say it doesn't work and quote joe_blow1 or joe_blow2 it doesn't make any difference how they THINK it should work. I've conceded that I believe there are some stretches that are probably too aggressive to be safe, but that doesn't mean that I believe all tire stretching is unsafe. @RotorDad nice, on the SVE link. I'm not sure how but the tire looks stretched in the video. Clearly I am mistaken, it must be the design of the tire. I totally get what you're saying about overstretching. I wouldn't personally do that because my spider sense tells me not to. But I do know the difference between knowing for a fact that it's unsafe and just having a feeling based on my understanding of physics that it doesn't look safe. Broadly categorizing all tire stretching is the same as broadly categorizing anything, it just doesn't work to take an extreme and base your whole argument on it. Ignorance allows people to broadly categorize all Muslims as extremists because a small percentage do something stupid. It doesn't mean there aren't many hard working, intelligent, kind Muslims in the world... it means some people went off the deep end and now people have to make an assumption about everyone and everything that can be associated that they don't understand. |
#3 | ||
The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group Last edited by vex; 12-23-2010 at 10:27 PM. |
#4 | |
I have experienced stretched tires. Thus my information seems more "real world" than theory. I find that whenever people discuss how things should work, and how things do work, it's completely different most of the time. Example: If you had never worked on a car before and you grabbed a Chilton's manual and decided to rebuild your motor, you would run into problems that aren't explained that real world experience would solve.
As for the tire inflation, I keep the tires at a reasonably high pressure setting of 40psi to maintain that the lack of flex in the elastic region. The thing is that you're arguing that I don't want my tires to act the way I actually want them to act. This is a preference, telling someone how they should prefer something is... useless. Technically I'm sure I'm putting more pressure on the sidewall than the manufacturer recommends, but I don't think it's more than the tire can take. If the tire can hold up to constant flexing from racing a car and being throw into corner after corner, it doesn't seem (to me) like it wouldn't be able to take that pressure as a constant. Otherwise it would be very common for people to have the sidewall blow out of their tires while racing. Obviously this is my personal opinion on the matter, just like you have yours. Without hard technically data that I can't prove my point and you can't prove yours. Your information is speculation and theory. My information is real world testing on my car (that I'm sure can be effected by a million different factors that I can't measure), my experience says it works though without detrimental effects. @RotorDad I did join just to argue. But that doesn't mean I'm not reasonable. If proven wrong I can admit it. The problem with this argument is that it's just like religion or politics. It can't be proven one way or the other yet people are talking like there's some proof. You can only argue your opinion on these matters, stating them as fact is inaccurate at best. Thanks for the welcome. |
#5 | |||||||||
![]() Plastic deformation is never good in such a thing. Quote:
Take a brand new tire prior to mounting. Measure all dimensions and record them. Stretch your tire and mount it. Run it a few times on the track, then remove the wheel and measure again. Are the measurements going to be the same? Depending on the amount of stretch will dictate whether you're in the plastic or elastic region of the material. Do the same with a non-stretched tire, dimensions will be almost if not identical. If you're stretching the tire outside of manufactures spec and then putting lateral load on the tire I guarantee you will be engaging in the plastic region.
