Old 11-22-2010, 07:01 PM   #1
Pete_89T2
Pete_89T2's Avatar
Mine is an Excailber something.... I can pull some measurements for you tonight if you like. Even the casters on mine are on the cheap side. They're getting replaced before I attempt to drop in my buddies V8 diesel. I've heard reports that the long-block weighs 1200lbs!
Thanks, but no need to measure. I just measured from the nose of my FC to its firewall, and the distance is longer than the max. 50-1/4" boom reach that the cheaper 1 ton hoist at HF gives you. Looks like the extra reach of the 2-ton model will be a necessity.
