|  11-15-2010, 01:51 PM | #1 |
| Good stuff at low prices Join Date: Oct 2010 Location: TX
				Rep Power: 16  |
			Make sure to clean the flange of the oil pan and the bottom of the engine really, really, really, really, really good before reassembly. Or the rtv/silicon will not do it's job. You may or may not use a gasket. That's up to you. Both ways work fine. You'll know its clean enough if your willing to put your mouth on it. It wouldn't hurt to just clean the oil pan up inside and out. Then you could even repaint it if you like while it's out.
				__________________ |
|  11-15-2010, 09:10 PM | #2 | |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  | Quote:
 I would NOT recommend painting the inside of the oil pan especially. If the paint on the inside of the oil pan happens to flake off (and most likely it will), I shudder that thought of all that paint flakes in the oiling system! Most people don't know that most metals are porous. Oil can actually soak into most metals - i.e. steel and aluminum. This is why the oil pan is a ROYAL PITA to seal. Most RTVs and most sealants cannot seal against metal that has oil in it. -Ted | |
|  11-16-2010, 06:34 AM | #3 | |
| Lifetime Rotorhead Join Date: Apr 2010 Location: Elkton, MD
				Rep Power: 16  | Quote:
