Physically, it's a 12 + 2 multitooth trigger.
It spins at half speed, so it's effectively a 12 + 1. It is effectively two gears stacked on each other - sync gear and home gear. It is triggered via magnetic pick-up's. There are no windows or slots - it's not an optical trigger, if that's what you're asking for. Orientation (for stock ECU) is dictated by procedure in the Factory Service Manual. This CAS is particular to all FC 13B's (turbo or non-turbo, minus some funky Euro-spec distributor models) and all Cosmo 13B-RE and 20B. They are all the same part number. -Ted |
Bookmarks |
