Old 11-05-2010, 06:30 AM   #1
dr50376272
dr50376272 is on a distinguished road
13b series 6 and 5
ok, i want to fit a series 6 13b turbo, 13b series 5 5 speed, in my rx4 coupe. right hand drive as i am in japan.
will the 12a turbo timing cover fit the series 6 13b? so i can make it front mount. will series 5 5 speed mate to series 6 motor with series 5 bellhousing? let me know people. also, does 12a turbo distributor fit 13b series 6 motor? allowing me to use a fuel only computer.
thanks guys !
dr50376272 is offline   Reply With Quote
Old 11-05-2010, 07:16 AM   #2
Mazdabater
FC3S
Why the heck would u go to the effort of putting in a 13B-REW in to still run the 12A dizzy? I believe the input shaft on the s5 box is 15mm longer but there are adaptor plates avaliable
Old 11-05-2010, 07:03 PM   #3
Garfinkles Motor Works
I am putting a 3rd gen twin turbo motor in a first gen car .I made a sub frame to mount the motor using the 3rd gen motor mounts because I do not trust the front cover to hold the torque of the twin turbo that may be modified above stock power levels .
Old 11-05-2010, 07:55 PM   #4
dr50376272
can you show me your setup? thanks !
