Old 10-27-2010, 04:18 PM   #1
PercentSevenC
Custom User Title
PercentSevenC's Avatar
The only difference between a "12A clutch setup" and a "13B clutch setup" is the weight of the stock flywheel. '83+ (12A and NA 13B) uses a 225mm clutch disc and pressure plate, whereas up to '82 used 215mm, but the parts are interchangeable (you can use 225mm clutch components on an early flywheel or vice-versa).
