Old 10-26-2010, 09:51 AM   #19
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
So Sunday I put a second coat of primer on, but not before a quick sanding with 400 grit.
Yep I finally bought more and higher grit sandpaper.
I also did something else to the car which Im not going to show until its finished.
So yesterday and today, Ive been going in an out because of the weather since its raining.
Ive been sanding the primer smooth, since the primer I used was from a can and I used a brush to put it on.
The one good thing about the rain is because the moister in the air, it helps with the sanding.
But today, fate told me to quit until the weather clears up.
(And among other reasons Ill post in my bridge-port thread.)
So I decided to put the front end of the car under the lean-too, so I could work on it even if its drizzling a bit. As I drove into under the lean-too I almost broke my passenger side mirror again by hitting the post. But I got away with it very lucky, since it did not crack anywhere. After that I took the mirror off just in case.
The first Time I broke a mirror OFF, was coming home one day and hit a tree while going around the driveway. This was when I had the original S5 mirrors, the ones with the holes through em.
I did have half a mind as to take the fender and bumper off and finish them inside the house, but decided it would be extra work.
I really hate rain.
Its really annoying when you cant do car work because of the weather.
