				Rep Power: 0 ![]()  |
				Fuel Hardline Diameter?
			Looking to get some adapters to go from my hardlines to -6 an (currently ghetto rigged with clamps)
	is the Hardline 3/8ths or 5/16ths? Something like this correct? http://www.summitracing.com/parts/EAR-165056ERL/ http://www.summitracing.com/parts/RUS-639200/ Thanks  |
				Rep Power: 19 ![]()  |
			It's actually metric like 8.0mm or 8.5mm?
	It's close enough to 5/16" SAE... -Ted  |
			 Clean S4 Nutswinger
				Rep Power: 18 ![]()  |
			Hmm, so using 3/8" ID rubber hose is incorrect?
			On stock hard fuel lines?
	No, they offer 5/16" size - it's a pretty typical size if you can't believe it. Make sure it's FUEL INJECTION rated. -Ted  |
			Alright thanks RETed I will double check and make sure about the pressure ratings
			 Simply Rotarded
				Rep Power: 17 ![]()  |
			5/16" ID and about 6' will get you from hard line to fuel rail, and fuel filter to fuel rail.
	LunchboxCritter - 91 NA to J-Spec TII - 88 FC Vert - 04 Rx8 Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn. DO NOT TRY THIS AT HOME!!!  |
			I would recommend hard lines over the engine. If you use hose, make sure and tie it fast to something so it doesn't rub and wear through.
	1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic)  |
		#8 | |
				Rep Power: 20 ![]()  |
	1993 Yamaha GTS1000 1992 Celica Turbo AllTrac 1987 RX7 Sport 1979 Yamaha G1, KM24 powered 1975 Dolmar KMS4  |
