Rotary Response Rotary Performance and Special Applications over 40 years rotary experience 3378 North Winstel Blvd. Tucson, Arizona 85716 520-327-6404 |
Rep Power: 10 ![]() |
I was told by a good friend of mine that had issues with a client constanly blowing fire seals that he did a little test. He ordered a bunch of new seals and put them in, tap water, distilled water, glycol, dex-cool, and water wetter. The seals in water wetter turned stringy and basically disolved.
I had a similar experience with an engine a long time ago that was running hot. Added water wetter, temps went down a little until the seals finally failed. I atributed it to corrosion but after hearing about that little experiment I started spreading the word. Certainly not the most scientific I agree but nonetheless, you can't really argue with the results. I may actually do this test myself with the next set of seals that I come across
Rotary since 1972
Rep Power: 17 ![]() |
Just as I thought, there in could be the problem. If a motor is built properly and to Mazda specifications or has never had a heating issue, gotten hot and warped a housing, coolant should never get near the seals.
That is the way the motor was designed. In a perfect world we would not even need seals. Two surfaces machined to 0 tolerance would not require any gasket or seal. Far too costly for mass production. So we have to deal with those few thousands. As stated, I have never had a failure of a seal by swelling or disintigration even in the bridge motor where the seals are exposed to fuel and possible coolant. I will try that test though, straight redline and also with the proper mix which is 4 oz redline to 1 gallon water. Still if coolant is getting to the seals there is an issue not related to coolant. Even so, we have used redline in motors that have just started to blow bubbles, FC's mostly, and got them to last a couple of seasons before having a complete seal failure. Most of those got hot a couple of times and there was no way to save them in the long run since they warped the housings. Seals were still fine except where they burnt out in the compustion area. Last edited by rx4ur7; 10-14-2010 at 05:47 PM. |
Bookmarks |
