Old 10-12-2010, 06:18 PM   #1
dr50376272
dr50376272 is on a distinguished road
sa22 clutch cylinder in rx 4 coupe does a sa22 clutch cylinder bolt straight into an
does a sa22 clutch cylinder bolt straight into an rx 4 coupe?
regards
dr50376272 is offline   Reply With Quote
Old 10-13-2010, 09:06 AM   #2
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
I used a NA FC clutch slave cylinder on my rx-4. I had to lengthen the pushrod a bit by welding 2 nuts on it. Other than that it works fine.
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 10-14-2010, 09:17 AM   #3
dr50376272
can you upload some pics so i can see what you did ? thanks
