Old 10-09-2010, 05:06 AM   #1
Originally Posted by JustJeff View Post
Though if I found some used FD stationary gears I'd do that and modify the e-shaft oil jets. I need to replace my stat gear bearings, so if I found some used FD gears in good shape I'd consider that modification
Something to think about...
The front FD3S stat gear is machined differently than the FC3S stat gears.
You might need to change out all the "front guts" in the oil cover to FD3S parts - thrust bearing plates x2, Torrington bearings x2, spacer.
