Closed Thread
Old 04-01-2008, 07:24 AM   #1
Barry Bordes
Barry Bordes's Avatar
Originally Posted by cewrx7r1 View Post
Those special coner seals should seal better, but where can you buy them?
If you had a good machine shop, maybe you could make them yourself.
The question is, where they not cost effective for Mazda, or only used in rcae engines?
Yes Chuck, I am not sure why Mazda hasn't used them for production. Possibly the extra machining and fitting.
I also wonder if the reason could be that the normal blow-by of the side seals might help to float the rotor between the housings.
As for who makes them, I make them myself with a special diamond cutting tool. I can cut a set for you.
Barry
Barry Bordes is offline
Closed Thread
