Old 03-31-2008, 07:28 PM   #1
RXtacy
RXtacy's Avatar
I might go with 850cc primaries instead of the 550s. If you don't have one already you should look into getting a boost gauge as well. I would also suggest an ignition upgrade, the HKS twinpower would probably the easiest plug and play option. While your engine is out check your motor mounts and wiring harness. If your motor mounts are worn I would recommend replacing them with noltec motor mounts while the engine is out. Do you have the stock radiator still? That could be a weak point in your system and wouldn't be a bad idea to change out to an all aluminum one as well. As far as the block off kit goes Banzai racing has the cheapest one I have found so far.
http://www.banzai-racing.com/
93 Frozen Grey Metallic FD
Build thread here
17 Camaro SS 1LE
04 RX-8 GT
but I'm getting old
Old 03-31-2008, 07:32 PM   #2
sm0keyii
sm0keyii is on a distinguished road
I forgot to list a boost guage lol. I was thinking 850cc, but RP told 550cc would be good for idle control. I already have a new radiator modded for the v-mount. I'll be sure to add the twin power to my list and inspect the mounts and such. Thanks for the help.
sm0keyii is offline   Reply With Quote
