|  07-11-2010, 05:18 AM | #31 |
| RCC Addict Join Date: Mar 2008 Location: Honolulu, Hawaii USA
				Rep Power: 19  |
			Do we really need to turn this into a playground spat? Can we drop the name calling? This thread is GOLD. Anyone who understands the data being presented knows that this kinda stuff is PRICELESS. I think this is the first time I've seen such data on ANY RX-7 type of forum. I've only read about stuff like this is SAE papers. To have a member actually messing around with such equipment is just unheard of. It would be sad if this thread gets closed. -Ted |
|  07-11-2010, 07:11 AM | #32 | |||
| Rotary Fanatic Join Date: Feb 2008 Location: Slidell, LA
				Rep Power: 18  | Quote:
 Not using two plus per rotor would definitely invalidate the findings. My third iteration spark plug is a –10 heat range TFX model, with a platinum electrode. The only negative effect that it might have on combustion is that it is ¾” vs the Rotary designed reach of 7/8”. Things to be tested are: with and without water, water/meth, splits, negative splits in vacuum, advance curves, port shapes, you name it. Barry | |||
|  07-11-2010, 07:40 AM | #33 | |
|  07-11-2010, 07:49 AM | #34 | |
|  07-11-2010, 08:15 AM | #35 | |
 My contact at TFX Engine Technology is Clint Gray. Their website has a better explanation of all the functions. http://www.tfxengine.com/index.html Their system goes for about 5k. The plug was $1300. All technical input is appreciated, Barry Last edited by Barry Bordes; 07-12-2010 at 09:44 AM. | |
|  07-11-2010, 10:14 AM | #36 | ||
| Test Whore - Admin Join Date: Mar 2008 Location: Right Behind you son
				Rep Power: 10  | Quote:
				__________________ -The Angry Stig- DGRR 2009, 2011, 2012 & 2013 - Best FC DEALS GAP!! WOOHOOOO!!!!! 2015 Audi S4 - Samantha - Zero Brap S4 2004 RX8 - Jocelyn - 196rwhp, 19mpg fuel to noise converter 2000 Jeep Cherokee Sport - Wifey mobile - Now with 2.5" OME lift and 30" BFG AT KO's! So it begins 1998 Jeep Cherokee - 5 spd, 4" lift, 33" BFG's - Rotary Tow Vehicle 1988 'Vert - In progress 1988 FC Coupe - Gretchen -The attention whore BEAST! I'm a sick individual, what's wrong with you? I'm pure Evil I'm still insane, in the best possible way. I think Brian's idea of romance is using lube. Your rage caused the meteor strike in Russia. The Antichrist would be proud of his minion. You win with your thread. Most everything It's a truck with a steel gate on the back. Just a statement of fact Motec M820, AIM dash, ported 13B-RE Cosmo, 6-spd trans, 4.3 Torsen, custom twin wg fully divided mani, Custom 4" split into 2x 3" exhaust, Custom HMIC, Custom custom custom custom I like to welder stuff.... No Bolt-ons allowed. Dyno'ed @ Speed1 Tuned by me - 405rwhp on WG.... WM50 cuming soon. -Angry Motherf*cker Mode ENGAGED- | ||
|  07-11-2010, 07:53 PM | #37 |
| The quest for more torque Join Date: Sep 2008 Location: Sheboygan, Wisconsin
				Rep Power: 18  |
			Sorry about the confusion, I thought the same thing that others did, this was a simple transducer installed in the leading spark plug hole. From what I have seen, there is more available power by building that peak pressure earlier in the cycle. If you are seeing detonation with earlier pressure peaks, 45 degrees is what you get. (This really isn't too bad, at is equates to 30 degrees on a piston engine. As I recall, 12-15 degrees is the sweet spot for peak cycle efficiency (on a piston engine). The rotary may be different. Actually, now that I think about it, the rotary has a longer combustion chamber and probably requires longer for the flame to propagate. This may mean that the pressure will spike too quickly is it is initiated any sooner, while taking too long to propagate if initiated at this time. Anyway, I hope that you are planning to analyze the effects of leading/trailing split. Some claim that it makes a big difference, I found no change on the dyno at all for pretty much the entire test. In fact, I unplugged the trailing plugs and saw no change under 6,000 rpm.
				__________________ 1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) |
|  07-12-2010, 05:36 AM | #38 |
| RCC Loves Me Not You Join Date: Jul 2008 Location: Influx.
				Rep Power: 20  |
			Barry do you know your %error on the calculations at all?
				__________________ The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group |
|  07-12-2010, 07:13 AM | #39 | |
 There are a lot of concepts to interrelate when considering what is going on inside of a rotary engine. This is from a Mazda paper Rotary86v6a4, Fig. 14, showing flame propagation. I think this is probably Mazda Research at its best! If you haven't seen it before please take your time trying to understand it.  Some things to note: Because the mixture is flowing the flame front hardly moves upstream at all. In fact the trailing portions of both flame patches are pushed backwards part of the time. The squish generation and trench shape further complicates this movement. When the leading and trailing flame fronts collide (at about 20º ATDC) that their speed diminishes. The knock region is from 30º - 45º ATDC and where the knock sensor is located. Barry | |
|  07-12-2010, 09:40 AM | #40 |
				Rep Power: 18  |
			The sensor specs are ±1% for Combustion. The timing trigger that I fabricated adjacent to Mazda’s timing wheel would be the area for greatest possible error. To check this a test run is then made where the engine ignition is cut at 6000 rpm and the throttle is opened fully. This double-checks TDC in relation to the logged actual compression hump. To my knowledge the rest are calculations.   |
|  07-12-2010, 09:20 PM | #41 |
				Rep Power: 18  |
			Correct me if I am completely mistaken, I will try to explain the figure. The diagonal lines indicate the position of each component as the rotor rotates. The angle indications are in rotor degrees, not eccentric shaft degrees. The distance from the left indicates degrees of rotation when that region of the chamber burned. The different lines are the different ignition timing settings that clearly cause significantly different behavior. The trailing side seems to be the weird one, the flame front displacement seems to shift nicely for all points below the leading plug. It looks like the flame front is traveling forward just fine, it is the backward part of the curve that confuses me. This would seem to indicate the the flame front follows the rotor rather than the housing (which makes sense, the rotor has the dish). I think I see why it knocks right above the trailing plug, the flame front actually reverses direction there (although not relative to the rotor). This must be right at the quench boundary at the edge of the rotor dish (probably when it meets the cusp on the housing). Do you know what the engine speed was for this test? Do you know the manifold pressure? (I would guess NA). It appears that at 20 BTDC, the leading front has basically dissipated by 45 degrees (Eccentric shaft, 15 rotor) (which makes sense why you observed the highest pressures when the peak occured at 45 degrees) Here is a theory about what is causing your knock on too much timing advance. Knock is typically caused by some shock wave colliding with the flame front (it can be a second flame front). My thought is that the leading and trailing sparks both touch off the mix in the chamber if the timing is advanced too far, this results in the two flame fronts colliding while they are stil moving very quickly. To test this, you could try unplugging the trailing plugs or adjusting the ignition split and observing what difference it makes. This research is awesome. Where did you find that diagram?
|  07-13-2010, 09:32 AM | #42 | |
 Barry | |
|  07-13-2010, 10:11 PM | #43 |
				Rep Power: 18  |
			Shaft degrees makes more sense in the diagram (the rotor would have moved quit a bit further at 90 degrees). I think I was second guessing myself. The reason I consider the ignition event to be at 20 BTDC is that there is observeable flame front propagation before 0 degrees, which excludes the ATDC option. It is strange that they neglect to indicate ATDC or BTDC. I saw the reference earlier, I meant where did you find the paper? Is that an SAE paper? This explains what I saw in several articles about trailing plug positioning, that further up the housing (rotor clears it earlier) is preferred for peak power. edit: It would be really awesome to see what the flame front does at 7,000 rpm....
				__________________ 1986 GXL ('87 4-port NA - Haltech E8, LS2 Coils. Defined Autoworks Headers, Dual 2.5" Exhaust (Dual Superflow, dBX mufflers) 1991 Coupe (KYB AGX Shocks, Eibach lowering springs, RB exhaust, Stock and Automatic) Last edited by NoDOHC; 07-13-2010 at 10:14 PM. |
|  07-14-2010, 10:17 AM | #44 | |
				Rep Power: 20  | Quote:
 If you know the calculations they're running for any given reading you can easily perturb the uncertainties to get a culmulative percentage of error. That way you can at least know the accuracy of your results. From my glances you could be on the mark or you could be slightly off. Without the error it's hard to gage application to different stress/repeatabilty.
				__________________ The Official FC Radiator Thread My Project Thread: Cerberus CCVT Virginia Rotary Group | |
|  07-14-2010, 05:27 PM | #45 | |
 For aircraft testing instrumentation we had to recertify sometimes every six months. I don't want to certify different dynos for the FAA or DOT. I want it to be accurate but I will pass on recertification. Really I just want to know is this log an improvement or have I gone too far! I am using it just like our Datalogit tuning for AFR, transition, etc. http://www.optrand.com/Papers/fisita98/fisita98.htm Barry Last edited by Barry Bordes; 07-14-2010 at 05:54 PM. | |
| Tags |
| barry bordes, bmep, imep, in chamber, pressure sensors, tfx |
