| Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's |
Any interest in developing an individual coil ignition system?
I think an individual coil ignition sustem (using GM or other readily availabe coils) would be an awesome product to add to your already bad ass line-up.
is there enough room to move all 4 coils to the frame rail, like your relocation bracket you already offer? |
Rep Power: 10 ![]() |
If you're serious about this, wait a few weeks until after I test a few coils. My gut tells me some of the GM coils are pretty weak and there are alot of better choices out there.
I'm serious, I'm trying to convert as much expendable components over to domestic/ more readily available parts.
as these cars get older, they will be harder to find good quality parts for locally. |
#4 | |
Waffles - hmmm good
replace those from any AutoZombie shop in the world if I have a failure.
My car has four Jabcobs C4 coils mounted on the finder side below the 929 brake master cyl .
Waffles - hmmm good
I went with 2 GM 4 prong HEI ignitors and 2 Ford TFI coils for my leading ignition and dropped the trailing. Works great.
How often do coils fail? I would rather replace the coils to get a stronger spark, not becuase they have a high failure rate.
The C4 coils are rated at 65 k volts plus I am using an AEM twin fire ignition module to fire them .
#9 |
#10 |
We've been using Electromotive TEC EFI systems & their Direct Ignition systems since early '80's (on all 3 generations of RX7's plus 3-rotor engines) with great results- cranktriggered ignition for extreme accuracy & "matched" individual coils,
http://getfuelinjected.com/products/directignition.php |
#11 |
20B
Rep Power: 17 ![]() |
Like This ??
http://www.dodo-logic.ca/?p=10868#more-10868 It is a Force Fed Built... 1993 Toyota 2WD ,Extra long ,wide bed . Club cab , Pickup ..with a 13B Cosmo Series 6 engine ,it has the oversized intake and Exhaust ports ( stock ) She Makes... 330 rwhp & 310ft-lbs of torque @ 16psi on Pump gas ..The power band is from 3000-7500 and totally set up for towing!..
Turbo is a a Holset HX-35 .... Transmission is ..Toyota R151 5 Speed (RWD) Manual Transmission ..... Differential is ... a one ton rear end (toyota) That is the larger 8 inch with a 4.1 Eaton LSD is true LSD. and rare 5 bolt 30 spline HD axles. .... Wheels are Supra tt 95 wheels. The offset is +50 8.5 front and 9.5 rear. Watch Dyno run at >> http://www.youtube.com/watch?v=_jVrozzi5Uk |
#12 |
Wow nice picture and the discription sounds very interesting ,good job .
