Rep Power: 10 ![]() |
Search newblet.....
oh shit, wait, wrong forum ![]() Basically what you want to do is create an excel spreadsheet that will calculate ground speed using rpm as a variable. You obviously need tire diameter, rear end ratio and gear ratios. This way you can input your RPM to determine your upshift rpm (what rpm the engine will drop down to when you upshift) to gauge where how responsive the car will be based on dyno charts. You're in luck, I built a spreadsheet exactely like that. It's on a comp that is no longer in existance but I did upload it to TeamFC3S back in the day. It's in the lounge somewhere I believe if ya wanna go look for it. We were discussing Renni 6-spds and doing a whole bunch o' calcs. You'll see what I mean in some of the graphs that are there showing the difference in engine RPM when using the Renni vs the TII shitbox. I specifically remember 7800 rpm redlines where fricken BEUATIFUL using that tranny for my setup. I set the rev limiter to 7500 becuase the torque came on sooner than I thought, and fell a little faster than I originally thought. Eitherway, head over and check it out. I would but I'm just taking a quick smoke break before I make a few final connections, add fuel and fire the FC .................. HOPEFULLY, fingers crossed.
