Rep Power: 10 ![]() |
Rears are still expensive, If anyone can find them for less that $140, I'd be interested.
Josh is right on the money though, they're sticking. If after a hundred miles or so and a few heat cycles of they don't loosen, replace them
[QUOTE=TitaniumTT;120028]Rears are still expensive, If anyone can find them for less that $140, I'd be interested.
Josh is right on the money though, they're sticking. If after a hundred miles or so and a few heat cycles of they don't loosen, replace them[/QUOTE $140 each or for a pair? FWIW, when I rebuilt my brakes this past winter, I picked up a set of semi-loaded rear calipers (has everything except pads, new shims & springs) for about $92 each from Brakewarehouse.com. Here's a link: [URL="http://catalog.brakewarehouse.com/ShopByVehicle.epc?q=1989-MAZDA-Rx--7-R--1308cc--1.3l--F/i--Turbo--Vin--13begi-Brake/wheel--Bearing&yearid=1989%40%401989&makeid=51%40%40MAZDA %40%40&modelid=10348%40%40RX%2D7&engineid=7972%40% 40R2%2D1308cc+1%2E3L+F%2FI+TURBO+Vin+13BEGI%40%407 972&subcatid=64@@Rear+Caliper%2C+Wheel+Cyl%2C+Hose s&mode=PA"] Pete |
