Old 05-26-2010, 10:02 AM   #7
Originally Posted by 89Rotary View Post
I've just finished breakin in my 6 Port Motor N/A and wanna SAFELY squeeze some power out. i just want to know basic's of where i should move timing, and when and how to play the Leading/Trailing Dance. Fuel i can Watch with a NB (WB Later) for now.
Honestly I could tell you some numbers, but there's really no need for a few reasons:
You can not tune fuel with a NB. It can only tell you if you're off stoich (rich or lean), but can't tell you how much. IE usually making peak power at a 12:1 AFR (or 0.8 Lambda). Consequently the timing is more sensitive to what type of gas you're using. If you're using regular (as stated by the Owners manual) stock firing is fine--can verify by strapping it to a dyno and going from there. If you want to adjust timing, you'll need to put it on a dyno (don't go by feel), and slowly adjust it from there. Depending on your spark energy you should see some decent gains (don't forget to go to a higher octane rating when you adjust it).
fuel tuning, rtek tuning
