Old 05-20-2010, 08:56 PM   #1
Nismo
400WHP or bust
Nismo's Avatar
Originally Posted by Max777 View Post
What I meant was, you take off the brake caliper, and then you hit the rotor in the space that the caliper left open? Should be plenty of room, no?
I don't know man, kind of hard in my 20x13 garage, and the only sledge I have is 12lbs.
Kevin, did you remember to touch yourself while everything was drying?
I touched myself after every step!
Old 05-20-2010, 09:07 PM   #2
You need to be careful there pumkin, especially with dirty hands, if you clean yourself off with acetone make sure you don't get any down your pee-hole.
Old 05-20-2010, 10:04 PM   #3
project86
Can't.Make.Up.My.Mind.
project86's Avatar
That sounds painful....
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
