Show your rotary car build up. Show off your Rotary Car build! |
Rep Power: 10 ![]() |
Sorry Michan.... I've had 'em, but didn't get my camera back until I had the FC flatbedded back to my place on Sunday. Here they are for the front. Rears need to be totally redesigned. I built a set from some flat 1/4" AL cut and drilled tapped but I'm going to get the original design adapted to work. I'll get some pics of that when I install the plates that I made.
Anyway, here they are, if you want a set for the front now, lemme know as I'm going to order some that are slightly different. The ones in the pics are 1/4" thick steel with some 1/16" washers. So the answer is some cut out of 5/16" and cadnium plated to prevent the rust. So lemme know if you want a set. There is only one more measurement that needs to be corrected. I had to file out the ID to fit over the hub. Yeah I have been, see the last set of pics to illustrate what we went through for basically nothing. Still so pissed. First 2 days I have off I'm realling thinking about heading down to the Dragon just because. I can count on one hand the number of days I've had off in the last 6 weeks and I've had about 5 hours to work on the car since DGRRX.... sooooo bummed.
So I figured I should give ya a few updates. Haven't really done shit since DGRRX, work has been kicking my ass to the tune of 10-14hrs/day 6 days a week. So I'm still thrashing every chance I get, but I've had no time as other shit keeps coming up, as in my mothers truck
![]() So anyway, here are some goodies Pic of the rear of the car showing the battery/fuse/main disconnect mounting.... and of course the bitchin' Lizard Skin MoTeC and TCMux mounting and wiring. ID2000 injector in my grimy hand, pair of ID 725's in the rail. These things just look impressive. If you've ever looked at the antiquated Delphi injectors that alot of us run, you'd understand. I really can't wait to start tuning with these injectors ![]() ID2000 in purple, ID725's in the rail. Good shot of the attention to detail of the CJ Motorsports Fuel Rail
CJ Rail installed. Really looking forward to getting them to build me a rail even though I just bought the GURU rail. The GURU rail has it's shortcomings as well but it's the BEST option that's currently available. And when they say 3-4 day delivery from AU, they mean it.
Anyway - CJ rail The big problem with the injectors and fitting them into the RE LIM is the 16mm+ opening for the injectors. I know alot of people just put a bigger o-ring on and call it done, but I was STRONGLY urged by Paul to NOT do that. So I looked around for the little adapter baskets and then a rail set to the right height and the Guru rail was it. Here's a pic of the little adapter bucket. And installed in the LIM The rail itself with the new ID2000's installed. If you look at the end, it's NOT a pipe thread as I would've liked to see. Instead it's a -8 ORB. Now, how does one get a 1/2"NPT Marren FPD onto a -8ORB fitting. The answer is you don't without a myriad of adapter fittings. I hate adapter fittings. So after a 9 minute phone call to MoTeC and a 2 day wait, this little gem of a package arrives. Bosch FPD, -6 Banjo, and an M18x1.25 to -8 ORB fitting. Who the HELL has a fitting like that? MoTeC - the only company that continues to impress me. Now, do I put it on the front of the rail to show it off, of the end of the rail to make the plumbing easier? ![]() And assembled
And this is what DGRRX will do to two seemingly normal people
![]() And yes, that is my car cover..... 1/4" flannel lined, very warm ![]() Still left to do wold be Plumb the fuel system wire up the GT101 Hall Sensors a few body panels to put on install the FTP's change a front caliper out Build a fuel cell - this is going to kick some serious ass.
Bookmarks |
