Removing the A/C.
Ok, so my car is a convertible... and it has A/C. Now, it works alright at the moment, but I autocross, and want to take it out to save weight. I know that it is a pressurized system, and that it needs to be bled so that you dont hurt yourself when removing it... more later.
BIIZZZAAAARRRRO
"Ooops, I accidentally just slit the a/c line with my 'gator knife, clumsy me."
After that, just make sure you move your head away from the engine bay. |
I can't believe it the same thing happened to me.
1988 Mazda RX-7 T2(list of mods here) http://designengineeringworks.com/project_cars.php 2004 Saturn Ion Redline(dd) 1999 Mitsubishi Galant V6(the backup beater) |
#4 | |
Rep Power: 21 ![]() |
OMG you too? Accidents happen. I felt bad for the atmosphere for a lil bit but forgot about it, till now.
so you just slit the line and duck for cover? That's all? Wow, that is on easy accident!
Umm, you guys arent just messing with me, are you? I really dont want to f**k anything up...
Rep Power: 22 ![]() |
Well, I did it a little different. I said, "Hey look at this tire valve on the A/C line, I should see if it unscrews with my valve stem tool."
Then I walked away and got some lunch.
#7 | |
naw, that's done on purpose. Ours were environmental accidents. Like Exxon Valdez but no news.\
EDIT: don't try to hold the tire valve open with your fingers.
Umm, so which line exaclty do I "depresurize at the dealer"?
Should I tell em to do the bick thick one, or the small thin one?
Rotaries:They are NOT that complicated! Last edited by Max777; 03-28-2008 at 08:37 PM. |
#9 |
yeah ive been wanting to remove the ac too, tomorrow ill go make sure the valve on my ac line is nice and loose.. i mean tight?
DD: 93' EG "Ferio" Sedan ![]() Project: 88' TII *Rebuild* Since Spring of 07'
#10 |
The one one I 'accidentally' removed was on the passenger side near the UIM. Maybe.
#11 |
2nd Generation Freak
I got lucky, I just unscrewed one of the hard line fitiings and someone had done the "dirty" part for me, no pressure, just lube. removed everything I could get to (still have the pump, fat hands don't fit well down there with the p/s still there) and called it good.
'87 TII- full emissions removal, a/c removed, FPD removed, dual 12" e-fans, Rotary Performance FCD, ACT unsprung 6 puck w/ Xtreme PP, custom open 2.5 inch exhaust, custom clutch pivot ball, K&N cone filter, TB mod, RB downpipe, motor blown 8/7/09 ![]() '94 Mazda B4000- POS beater truck, stock "The easiest way to fail is to never try." - Me |
#12 |
Side note: If you do happen to inadvertently remove the valve from the line, or remove a line, be sure to cover the car, or have a fan blowing away from the majority of the car. That friggin PAG oil will get EVERYWHERE.
Ask me how I know.
#13 |
how do you know?
#14 |
Well, I'm thinking 2 things: Wear some nice and thick gloves, and put a huge ass towel in front of one of the schrader valves...
#15 |
So, uh... today my hand slipped, and I accidentally cut that big thick AC line that is right by the master cylinder. I mean, it like, went all the way through, except that nothing came out... is this normal? Or is my system depressurized already for me?
