Needing a new tow rig.
well little update. my DD ended up in the body shop for a couple days for a door ding. so i rocked the FD for a few days finding more refinements i need to take care of. the exhaust has a very nice rotary tone to it although i think its still a bit loud for my taste so it looks like ill be getting another bullet resonator/muffler installed and exhaust wrapping the mid-pipe.
BUT during the DD time my coolant temps started getting hotter i figured cause it was warming up BUT then it continued warmer making me look into any causes. NOT overheat hot but just warmer than it should for the cooling setup i have and fan temps. never got above 97c. turns out my fans were dieing. well i picked up some new fans off rx7club and apparently there are differences in the fan setups for different years im assuming although iv not seen any others like what i had stock. left fan 4 wire right fan 2 wire single speed and they were counter rotating fans the replacments i made sure i got both fans 4 wire 2 speeds each for all my fan speeds i should have. and the fans both turn the same direction on these. also a small little thing the fans housing/mounts were different too mine had wire clips for the wires the other new one didnt. but i swapped housings as the one i got had bolt holes clipped out. NOW my coolant temps are exactly where i expected them to be even without ducting still. a bit of thrashing havent seen above 87 lol. to round out the cooling system i got in the sakebomb dual oil cooler GB#2 and ill be getting those in about a week or so dual 25rows ohhhh yea! ill also be installng the sakebomb HID projectors at the same time as the bumper will be off already. and currently getting the suspension ready for final overhaul. pics to come soon most likely this weekend as its raining all freaking weekend z |
