Ask Me About My WANKEL!!!
ok so i tested coils all showed fine
, so i hooked it up to ignition scope i found that my trailing wires are bad so i unhooked trailing and ran just leading to see if same issue, of course same miss, ignition scope looked good... so i hooked up timing light, timing seemed fine... but while i had it hookep up i noticed that one one of my leading wires the signal would drop out with the miss so i put timing light lead next to coil, and found that one side was randomly losing fire, how this is happening i have no fin clue at all.. im hoping this was the issue but not sure if this would cause my dieing at stoplight issue. my buddy has an s5 thats gonna let me use his coil and wires so if that fixes it i know what im gonna need if not ill update... any idea on the dieing at stoplight???
1984 Rx7 Gs - stripped interior re speed coil overs, tokico blues, re speed crossmemeber and mustang rack, diamond star racing wheels 1988 Rx7 Se - Sold 1988 Rx7 GXL - Sold
#2 | |
The stock ignition system cannot handle constantly firing everything properly. (This is why we run CDI boxes to "fix" this problem.) It's not the cause of your problems, unless it's triggering a larger problem down the line... -Ted |
only one side of the coil is dropping out and this is happening at idle.
#4 | |
-Ted |
"When the pulse switches from high to low, the igniter turns off the current in the primary leading coil winding. Since there is only one leading coil and there is no spark distribution, both leading spark plugs are arced. Obviously, one spark is wasted but with no ill effects."
This being a wasted spark i still do not see how one side of the coil "drops off" and then just starts working again, both sides of coil recieve the same signal and spark.. so im just not seeing how this is normal?
To understand what's going on, you need to understand the dynamics of wastespark ignition...
Most people understand the part about a dual tower coil firing into two "chambers" at the same time, but it's what's happening on the spark plug end that makes it interesting. A spark plug firing into a compressed chamber requires more power to overcome the (spark plugs) gap - as compared to firing at "0 atmosphere" or outside of the engine. Add fuel into the whole mixture (no pun intended), and it gets even harder to fire. A spark plug firing into a chamber that has already ignited is surrounded by ionized gases and particulates (combustion by-products) that helps the arc jump the gap. Add to the fact that the later scenario is usually at the tail end of the combustion cycle (and starting into the exhaust cycle) which means that pressure in the (compressed) chamber is starting to drop at this point. Less pressure = easier for the spark plug to fire Now, let's look at the wastespark, dual tower coil... It's just a step-up transformer with the two tower (outputs) coupled. Fire voltage through the low side, and it gets stepped up by the coil depending on the ratio of the windings. Now, the coil can fire either: 1) tower 1 2) tower 2 3) both towers Most of the time, it does fire through both. When it doesn't have enough power, it tends to fire only one side. Now, remember earlier about the imbalance of the chambers? Guess which side it's going to fire if it had to pick? Due to this phenomenon, this is why the coil drops one side occassionally. rising chamber pressure + fuel = increase resistance to spark plug arcing the gap dropping chamber pressure + burnt gases = decrease resistance to spark plug arcing the gap This is why a totally stock ignition FC will sound like this when idling... brrrrrrrrrrrrrrrrrrrrrrrr, brr, brrrrrrrrrrrrrrrrrrrrrrr, brr, brrrrrrrrrrrrrrrrrrrrrr Even with the car in top shape and running perfectly, the wastespark is still dropping a spark every so often. That small hiccup is an ignition misfire. Partially to blame is the inadequate electrical charging system in the FC. The stock FC alternator SUCKS. At idle, the alternator is barely producing enough voltage to charge the battery. Once the RPM's climb, this isn't much of an issue, so you don't get misfires above idle speeds. We fix it by installing CDI boxes which totally cures this "problem". I run a Crane Cams HI-6 myself. I usually install CDI boxes in all my customer's cars. -Ted |
