Old 04-26-2010, 11:39 PM   #1
Akagis_White_Comet
Comealong busts your nuts
Akagis_White_Comet is on a distinguished road
Not necessarily Ted, just illustrating what the possibilities are by mixing the original ratios together. By putting a manual diff's pinion gear on an automatic diff, Mazda ended up with the GTUs's ratio of 4.3:1. To get 3.727:1, you simple do it the other way (auto pinion in manual diff).
in short:
US-spec Auto diff + US-spec Manual diff = one 4.3:1 GTUs diff and one 3.727 diff (7" ring gear family)
J-spec Auto FC diff + US-spec TII diff = one 4.3:1 Infini IV diff and one 3.727:1 diff (8" ring gear family)
FD Auto diff + FD Manual diff = one 4.3:1 FD diff and one 3.727:1 FD diff (8" ring gear family)
Plus, if Aaron Cake can put down 407hp and 360ft.lbs on a N/A drivetrain with open diff for 2 years straight with no issues, suffice to say that it is hearty enough for a 20B running stock twins at least untill the owner can afford a proper TII drivetrain swap. But with a single turbo conversion, it'd probably be pushing a N/A drivetrain too hard as you suggested.
Now all we need to get are part numbers for the J-spec FC Auto diff's pinion and ring gears. Can someone overseas hook us up?
Akagis_White_Comet is offline   Reply With Quote
Old 04-30-2010, 11:37 AM   #2
Black91n/a
Black91n/a is on a distinguished road
Won't that not work because of the differences in ring gear thickness to compensate for the different pinion gear sizes?
For the 7" ring and pinion, in the short noze size, you can get all those ratios that I mentionned as factory matched sets made for each other. No, it's probably not the best for a 20B (maybe NA), but for someone wanting differnet gear ratios without the limitations of the long pinion housing, or the expense and possible reduction of strength from a welded pinion, it's a realistic option I think. I think that if one wanted several diffs in different ratios for differnet tracks for instance, it'd be the cheaper, easier way to go.
Black91n/a is offline   Reply With Quote
