RX-7 3rd Gen Specific (1993-2002) RX-7 1993-2002 Discussion including performance modifications and Technical Support Sections. |
Sua Sponte
Given your narrowband O2 Sensor is by no means the most accurate, .02 means you are running very lean. On a stock O2 Sensor if I remember correctly, the "ideal" voltage is .45... which means it is at an optimal air/fuel mixture. Anything below that is lean, anything above that is rich... relatively... based on the number. I'm sure you already know that, I just wanted to throw that in there for anyone in the future that may experience the same problem as you that is searching.
Does it always lean out at 4000rpm's or only when under heavy acceleration?
Road Atlanta August 2011 NASA TT 1:33 http://www.youtube.com/watch?v=IFY00PAK_Ps Traqmate's video of my car from the 2011 UTCC at VIR http://www.youtube.com/watch?v=2Zcn6...layer_embedded Video of Yellow LS1 FD at NASA TT at VIR http://www.youtube.com/watch?v=e6k0lJkcwrM |
Administrator
Rep Power: 10 ![]() |
It only runs lean when under boost, I can gradually accelerate the car to 6000+ and it reads .84 to .89
Rep Power: 10 ![]() ![]() |
I agree with Brent... narrow band is useless.
First of all, Check your ground. Make sure the ground to your engine is good. If your car was running fine before, it shouldn't be anything to do with the tune. Also, since you are non-seq, there shouldn't be much troubleshooting regarding vac lines.. Check those just incase..
Administrator
Checked for vacuum leaks and found none. I pressurized the intake with 5psi useing my air compressor.
I bet it is related to my leading coil pack or msd6a or it could be a drop in fuel pressure but i don't know because my gauge is under the hood, Hard to read while driving. ![]() |
#5 | |
Administrator
That is what I am suspecting also, I cleaned the plugs. but still same results. I am useing a 2nd gen leading coil pack with a MSD6A. This weekend I'll desolder it all and reconnect it to reassure me it's not a loose wire. how do I verify the MSD6A is working properly? Or maybe my leading coil pack is going out again. I had previously blown a stock leading coil pack with this setup. It literary blew it apart. |
Bookmarks |
