|  04-12-2010, 03:31 PM | #1 |
| ZOMG WTF BBQ!!! Join Date: Mar 2008 Location: Mobile, Al
				Rep Power: 18  |
				Simplifying the engine bay
			I've been on a mission on cleaning up my car and making it a little bit nicer/cleaner. I'm finally gonna start screwing around with my engine bay. I searched around but I couldn't really find much... I have a 1985 GSL-SE and I was wondering which stuff I can pitch out and what stuff I actually should keep. I don't have to worry about emissions and I'm gonna ditch the air pump once I buy some new headers and delete the cats. My Car doesn't have power steering. My AC has been fried since before I got the car so that's coming out. I'm going to relocate my battery some where else. I'm have my hands on an e fan so my clutch fan is coming out. I seen a few threads about the charcoal canister and I'm still on the fence about pitching that. After I get those Items removed I'm going to replace all the hoses, washers, etc since I have a leak somewhere... Then I'm going to go to town with degreaser and paint my radiator shroud. Is there anything else worth pitching (I'm doing this for the sake of simplicity and the clean look)? Or Any vacuum lines I can delete? |
|  04-12-2010, 04:03 PM | #2 |
| RCC Contributor Join Date: Mar 2008
				Rep Power: 18  |
			head light motors, fuel injection (since the 5th and 6th ports wont open when you ditch the cat)
				__________________  85 rx7 gsl-se - AA tags/ never ending project will never run |
|  04-12-2010, 11:13 PM | #3 |
| tumor-syphilis-itis-osis Join Date: Sep 2008
				Rep Power: 18  |
			i'd stick with leaving everything where it is, stock is best unless you build the motor especially on the gsl-se, I worked quite hard to get mine back to stock and its wonderful
				__________________ 82 300d 82 Gsl 84 b2200 Diesel 88 gxl |
|  04-13-2010, 04:23 AM | #4 |
| RCC Contributor Join Date: Feb 2008 Location: Grand Rapids, Michigan
				Rep Power: 18  |
			When I did my engine bay a few years back I took some photos and put together a little example of what you can remove, what you can move, and where you can put it.  Also, how I went about  performing the actual cleaning of the engine bay.  Unfortunately, since this was a few years back, you can guess where this writeup is located.   http://www.rx7club.com/showthread.ph...highlight=pics Not sure how much will apply to your case, since you've got an SE, but at the very least the cleaning instructions may help you out. Best of luck with your project.  .
				__________________ "Learn from the past, or it will become your future...." '85 GS 12a + LSD/Sterling carb/Respeed coilovers/Respeed front swaybar/Respeed adj. rear spring perches/Illuminas/Bilsteins on rear AutoX vids @ http://www.youtube.com/user/Kentetsu1 |
|  04-13-2010, 11:34 AM | #5 |
				Rep Power: 18  |
			^Thanks. And there's not a whole lot i can remove. i'll just move my battery and put in the efan and call it a day. then i'll get to clean up the grime....
|  04-13-2010, 08:40 PM | #6 |
				Rep Power: 18  |
			efan really does no good, you won't get the same flow
|  04-13-2010, 10:26 PM | #7 |
				Rep Power: 18  |
			I want it for the sake of cleaning up under the hood. And I may do an engine swap in the future so i'll have more room to work with.
|  04-14-2010, 05:33 AM | #8 |
				Rep Power: 18  |
			Done right, an Efan is a great mod.  My MR2 fans do a great job of cooling the engine, better than the stock fan ever did.  And it really frees up some power that you can feel in 1st and 2nd gears. If you relocate the battery, are you putting it in the passenger's side storage bin (like you should)?   |
|  04-14-2010, 09:43 AM | #9 | |
				Rep Power: 18  | Quote:
				__________________  85 rx7 gsl-se - AA tags/ never ending project will never run | |
|  04-14-2010, 12:27 PM | #10 |
				Rep Power: 18  |
			Yep, the battery is going to go behind the passenger's seat once I get a box for it.
|  04-15-2010, 03:35 PM | #11 |
| RCC Addict Join Date: Feb 2008 Location: Middle TN
				Rep Power: 19  |
			with the right header they will. Check out Mazdatrix they made the one on my gsl-se
				__________________ I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) |
|  04-15-2010, 10:21 PM | #12 |
				Rep Power: 18  |
			And the RB Presilencer will let you retain the abilities of the 5 & 6 ports as well.
