| DGRR Archive Threads from Previous Deals Gap Rotary Rally Events. |
FD Black leather Seats in A+ shape (from my 38K mile FD)
$700 cash New Konig Rewinds 15x7 with good used rubber (3/4) 205's Gun gray with polished lip 4x110 $700
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) Last edited by fire85gslse; 04-15-2010 at 01:25 PM. |
Home-brew Rotary
Internal engine / block parts. S5 NA
I'm bringing a box of some internal/external engine parts, (I will list below).
I'm not bringing the the housings or irons, unless someone posts that they want one of them or more. Like I stated before, the housings/irons, most of them are in bad shape, so I figure most ppl would not care for them. But unless you want something ill bring it. List of engine parts: (all parts have been cleaned.) $30 > Oil pan (good condition, a few scratches on bottom.) $60 > Front cover (good condition) $25 > Front Stationary Gear (light surface rust) $25 > Rear Stationary Gear (light surface rust) $40 > Oil Pump (made sure still lubed) $10 > Front Counter Weight $5 > Oil Pump Chain (made sure still lubed) $5 > Oil pressure Regulator (made sure still lubed) $5(ea.) > Drive gears, flywheel nut $1(ea.) > Thrust washers, Spacers, Plates $1(ea.) > Dowel Pins $5(set) > Tension Bolts Rotor parts: $25 > Compression seal set $25 > Oil ring carriers $10 > Oil ring springs $10 > O-rings Also bringing some other items: $25(ea.) > Rear Hatch Shocks (from a GXL) $5 > Gauge cluster plastic cover (houses the lights, wiper, blinker, etc. switches)
'89 RX7 GTU, half-Bridge-port S4/S5 NA, E6K, Full RB exhaust, weekend warrior. '83 RX7, The "this might take awhile" project. '87 RX7 GXL, Rest In Pieces. '98 Subaru Impreza Outback-sport, rx7 rescue vehicle, down for repair. '94 Ford Ranger, daily. Last edited by N.RotaryTech; 04-15-2010 at 02:35 PM. Reason: Items added. |
